View Full Version : C220 freezing when receiving print job
Mooseface2r
10-02-2013, 04:36 PM
Hi, i have an issue with a C220 freezing when receiving a print job. it will print the first page but then freeze. so far i have done the following with the same result.:
Changed network cables
Tested with crossover cable
Replaced MFP
Reloaded Firmware
Has anyone had this before or can suggest what to try?
Cheers
Mooseface
JustManuals
10-02-2013, 04:43 PM
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
HP:guy
10-02-2013, 04:55 PM
When you say tested with crossover cable was the print successful?
Have you changed the Driver?
Mooseface2r
10-02-2013, 05:06 PM
Tested with crossover cable - it was not successfull.
have tried a different driver and a different laptop with no joy
jjohnston12385
10-02-2013, 07:36 PM
Potential HDD or RAM problem in the copier? I've had HDD problems do some strange things.
Mooseface2r
10-09-2013, 09:27 AM
Hi Guys, Changed the hard drive and this solved the problem for about a week and now its doing it again.
Anyone got any idea what might cause the hardrive to crash out like this? it seems strange that 2 would develop the same fault within a week.
blackcat4866
10-09-2013, 12:55 PM
When you've got Gigabit network capabilities on a 100Megabit switch, this can happen. What you need to do is select the 100MB communication speed from the web interface. =^..^=
Mooseface2r
10-15-2013, 03:43 PM
Hi Guys, thanks for the suggestions everythings been tried here.
Its not throwing up any codes but the job details shows the error as "power off"
CrapAimer
10-15-2013, 04:13 PM
Have you done the firmware update
Mooseface2r
10-15-2013, 04:30 PM
i have reloaded the firmware...you say "the firmware update" is there one out for this fault?
EarthKmTech
10-15-2013, 10:37 PM
It seems the only thing you havent tried is the ram, which is what i would of tried along with the MFP board for an issue like this.
more extreme measures may be needed next if this doesnt resolve the issue.
Also, regarding the hard drive, if you replaced it with a KM supplied hitachi it's not unusual for those to fail almost immediately.
dirtyfingers
10-16-2013, 10:24 AM
this might be a strange request
But I would change the IP address
Did the C220 replace another device ?
Did it use the same IP address
The C220s are not known for lockups
you may find it works fine when you are printing from a crossover cable.
if there is a GPI driver pointing to the C220 ...this could cause the panel to freeze.
Avskrap
10-16-2013, 12:59 PM
Is it a PS job from some Linux dist?
We've got an ongoing project with the department of computer science at one of the local institutions for higher learning where they've got a C220 that freezes when recieving certain jobs.
Konica Minolta have been assisting us and the customer directly, the only solution they've got is special FW (GCD-D1 to be more precise).
Apparently Ghostscript is causing these problems and it's ongoing, with newer versions continuing to cause issues and KM can't seem to do anything but to release obscure special FW.
