EarthKmTech
10-03-2013, 12:40 AM
anyone had the annoying issue on the e series yet when using account track where by the machine will go into a state of lock down and accept no account track passwords at the panel and also reject the administrator password?
the only way to get around this is to switch the machine off at the main switch and restart it. It may happen once a day, once every few days, or once a week.
The only permanent solution I have found is to format the hard drive / replace it and setup the machine again from scratch, which is a collossal pain in the butt. You can not backup and re-use the account track data as you will transfer the error back to the machine and you will be back to square one.
All e series machines appear to be affected 224 - 754 and firmware doesnt fix it. Some machines do it, others dont. I'm thinking theres something wrong with the way the machine writes the initially created accounts to the hard drive, or possibly it happens if the accounts are being created via the web interface and it times out during one of them due to a slow operator.
Km don't want to do anything about it. All hard drives that have been replaced have tested out 100% perfect with zero bad sectors on a computer, its not a hdd failure.
