Abort Code bizhub 250
  • alfpanasonic
    • Jan 2007
    • 73
    I have this abort Code:
    Abort Code 0X00DC0652
    Any sugestion?
  • sanchez
    A blank page prints and Abort Code 0X00DC0652 is indicated when copying from the ADF.
    CAUSE: The scanner locking mechanism has been switched to the locked setting. The Exposure Unit cannot reach the slit glass position, but can still copy off the platen glass.
    SOLUTION: Access the scanner locking mechanism on the upper left side of the main body. Ensure that the locking switch arrow is pointing to the unlocked setting.
    OR check home position sensor
    • alfpanasonic
      • Jan 2007
      • 73
      The lock in in position
      • Scott_Lewis
        • Mar 2007
        • 519
        Any sugestion?
        Does the scanner try to beat itself up at the end of the scan bed? Check the home position sensor.
        • alfpanasonic
          • Jan 2007
          • 73
          Home position sensor is ok.
          I think that may be the scanner motor or PWB assy (control motor, sensor, lamp).
          I'm waiting this spars parts.
          • alfpanasonic
            • Jan 2007
            • 73
            250 ok
            After this day's the problem is solved,
            It's a fuse in Power Supply.
            • canrajedwin
              congrats good effert
              • hindsjosephine
                Great quality! Viagra No prescription needed!
                Great quality! Buyviagralowcostonline Buy cheapest online viagra buy cheapest viagra online Viagra No prescription needed! Buyviagralowcostonline Buy viagra online without prescription buy viagra onlinehttp://buyviagralowcostonline.wikispaces.com/Buy+Viagra+in+Australia buy viagra in australiahttp://buyviagralowcostonline.wikispaces.com/Buy+Viagra+in+Canada buy viagra in canadaCustomer support available 24/7! Viagra licensed and FDA approved! Buy from us at the best prices Viagra and others by 70-80% cheaper!Buyviagralowcostonline Buy viagra online in United Kingdom buy viagra in UK Fast worldwide shipping!Connotea: Community Profiles: parsondominik buy cheap viagra Fast worldwide shipping!musgravetylor | Script Frenzy viagraViagra No prescription needed!YouTube - musgravetylor's Channel viagra cialishttp://www.youtube.com/group/viagrapharmrx viagra online cheaphttp://www.flip.com/people/flipbooks/484267 viagra onlinehttp://getk2.com/forum/member.php?u=89447 buy viagra online
                • elton
                  hi i had the same problem for the last 2 days i replaced boards , motors and today i adjusted the scanner position and the problem was solved
                  • codeboy
                    how to adjust scanner position...
                    i can slide the scanner bar to the right, but then it cruises back to the left... then beats itself up (bizhub 200)
                    !*! ABORT !*!
                    code = 0x00dc0652
                    tskname = tRT22601
                    tskID = 0x00005849
                    sp = 0x89f308a8
                    ra = 0x812733a8
                    build_3034.070219
                    Any Ideas?
                    Thank you
                    Last edited by Guest; 09-21-2010, 08:48 PM. Reason: sorry moved to new post... didnt mean to hijack
