View Full Version : Jamming Bizhub 501 paper jamming in registration area
vijaysharma
10-07-2013, 06:23 PM
Hi,
I'm facing the jamming problem in Bizhub 501. problem area registration clutch.
what i done, I checked registration clutch it is ok registration sensor also ok
secondly i checked the PRCB board it is ok, checked the OACB board also but problem is not rectify,
is anyway to solve the problem:confused:
JustManuals
10-07-2013, 09:49 PM
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
mo0651
10-08-2013, 02:04 PM
I don't know what you mean by checked clutch?!? These clutches are known problems. There are two different ones right there. Change them both while you have it apart.
copier addict
10-08-2013, 06:32 PM
mo0651 is right. Replace the clutches in registration area.
emujo
10-08-2013, 08:44 PM
Hi,
I opened the side door and the clutch did not fall out, there is a registration sensor in the place I think it's supposed to be, I didn't see any smoke pouring from the PRCB or OACB so they should be OK also. It must be a piece of crap machine that can't run a single piece of paper and needs to be replaced, not my troubleshooting skills. Emujo
vijaysharma
10-09-2013, 11:50 AM
Hi again
mo0651 thanks
i replace the clutch, registration sensor,PRCB board and OACB board also
but the problem is not rectify:confused::confused::confused:
copier addict
10-09-2013, 02:08 PM
Hi again
mo0651 thanks
What jam code/codes are you getting?
mo0651
10-09-2013, 02:15 PM
Jam codes?? There are two clutches there, Did you replace both? Are the rollers turning?
vijaysharma
10-11-2013, 10:25 AM
HI,
jam code is J-3100:confused::confused::(
vijaysharma
10-11-2013, 10:27 AM
again
both clutches replaced and rollers not turning
rahadyan himura
11-18-2013, 09:13 AM
Hi,
yeah, if you copy single is okay and if you copy double sided and jammed at registration roller, right?
you need to check and give some oil at (26NA 2024 2) SEPARATE GUIDE PLATE. if still same of course you need to change registration clutch (57AA 8203 0) CONVEYANCE DRIVE CLUTCH.
i hope this can help you.
