View Full Version : Miscellaneous Bizhub C7000 banner printing (long sheet)
Saghir377
10-10-2013, 12:24 PM
Hi good after non to all Dear just i want to know Dip switch setting fro long sheet printing from bypass (330mm * 750mm)
kindly help me
Dip switch 10.0
set the dip switch to '1' (on)
this then enables the banner mode function under user settings.
Note machine must be rebooted after banner mode is activated.
Banner mode maust be turned off and machine rebooted for normal printing
geralditec
04-01-2014, 02:53 PM
Hi, I have a bizhub C6000, with finisher FS-612. I can print 300x900mm banner page but jams/ stops in finisher, and printing completed, so not stuck in fuser, just in finisher, then. I have to remove manually from finisher. Page fully printed but I can't get it to exit properly without doing manually by hand. I did change the dipswitch 10.0 so i can select sizes, just the exiting from finisher that is problem. Do you maybe have any suggestions?
obejean
05-01-2014, 12:24 PM
geralditec, you have to remove finisher to do banner printing, only supported with output tray, hope this helps:D
Dip switch 10.0
Can You please tell me where I find this dip switch??
Mick01
03-11-2015, 01:12 AM
Hi,
Dipswitch is acessed from service mode- system setting- software sw setting
In regards to the finisher jamming issue. It will not jam if the paper weight is set under 135gsm. This weight range will run the engine at full process speed. Any slower it will drop to 2/3 speed and will not exit the finisher in time. If you require paper above this weight then you unfortunately have to remove the finisher.
Hope this helps.
khattab.al.masry
03-18-2015, 11:29 AM
I hope the following attachment that help you.
and also the following link.
http://www.copytechnet.com/forums/konica-minolta/21864-bizhub-pro-c6500-banner-printing.html
