View Full Version : Miscellaneous IR3570 finisher S1 issue
adel_nathan
10-23-2013, 10:43 AM
hi every body
i have a problem in photocopy machine IR3570 with finisher S1
the problem is when paper get out from finisher , the roller dosn't get it back to hold it with three arms
and some times paper scew
that make a lose of some paper from staple
and make diarrange of paper
i change the roller and no change
i hope you understand my bad english
please help
thanks
canonbundy
10-23-2013, 12:15 PM
hi every body
please help
thanks
Inner Finishers have a habit of frightening the heck out of Techs ie, the units are seldom included in the Machine Servicing.
There is only a half a dozen screws in the covers to access the Transport/Delivery Rollers, shafts & bushings for lube, make sure these and the large exit rollers are cleaned properly (I use Meths)or replace them, the main reason for skewing & mis-stapling.
blackcat4866
10-24-2013, 02:05 AM
The grippers on the S1 inner finisher were modified. I didn't discover it though, until I had one break the front gripper. My machine errored out E000575-000 then isolated the finisher. It did it about once every 30 days.
Replace stack delivery slider (4F3-0243-000), operation tray (4A3-1044-000), and Op Tray Sheets (4A3-1074-000). =^..^=
teckat
10-24-2013, 10:04 PM
hi every body
please help
thanks
============================================:cool:
As the machine ages, the following parts should be inspected.
Quantity
Part Number
Description
Location
Comments
1
4F3-0243-000
Stack Delivery Slider Assy
Q11-1
Comes with Q11-12 / base plastic may break off
1
4A3-1044-000
Tray, Operation
Q11-5
Notch worn from wear
2
4A3-1074-000
Sheet, Operation Tray
Q11-6
goes on Q11-5
0
4A3-1055-000
Shaft, Claw
Q11-10
Be careful not to break
0
4A3-1080-000
Sheet, Stack Delivery Guide
Q11-12
Comes on Q11-1
0
4F3-0241-000
Solenoid, Cable
Q21-11
Clean
0
Gear 64T
Q21-16
Clean and lube
0
Gear 34T
Q21-17
Clean and lube
1
4A3-1109-000
Roller, Paper Feeder
Q30-3
Delivery roller
0
4A3-1110-000
Rack, Offset
Q30-4
Clean and lube
2
4A3-1121-000
Roller, Offset
Q30-14
Delivery Moon Tires
0
4A3-1059-000
Lever, Pressure
Q21-6
Breaks off and binds paper sensor causing the tray to lower all the way
Make sure the inlet guide to the Finisher-S1 is not bowed
:mad:
part number 4A3-1070-000
If the Offset Rollers (4A3-1121-000) have become worn or damaged, the paper may not fully eject from the Finisher. If the Offset Rollers are worn or damaged they should be replaced.
http://www.techsupport.cusa.canon.com/cd/12/resources/26004.jpg
Canuck
10-26-2013, 10:31 PM
Is everything moving correctly mechanically? If not could be finisher board..i would pop one in quickly to check...takes 5 min. I've changed a few finisher boards on these
