View Full Version : Jamming bh c220
jackson007
10-28-2013, 03:08 PM
hello engineers
i am facing a problem in my costomers machine bh c220.bypass feed roller is continuosly rotating,so papers are going inside continuously and getting paper jam.
why feed roller continuosly rotating,i cleand feed clutch also.
emujo
10-28-2013, 03:38 PM
Electrically disconnect the feed clutch, if the roller stops rotating then you have a PRCB problem, or a short in the low active wire. Emujo
blackcat4866
10-28-2013, 11:48 PM
Conversely, if the shaft still rotates after you've disconnected it electrically, you've got a seized clutch. =^..^=
jackson007
11-04-2013, 04:23 PM
i removed connection then cheaked.clutch still rotating so i desided as clutch was stucked
thanks for responded engineers
JustManuals
11-04-2013, 06:48 PM
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
http://www.justmanuals.com (http://www.justmanuals.com/)
paul@justmanuals.com
