Synaux
11-03-2013, 07:37 AM
I got a 601 that the !@#$ing web roller wrapped around the upper fuser roller (my fault for leaving slack like a moron--this is why I avoid work when feeling crapulous).
Okay, so I did something stupid, but I got that nasty stuff out of the roller with some care and performed a full PM (including drum and developer) and installed a new web roller all at once.
Now, the entire fuser section will not heat up at all.
I get alternating 3901 and 3803 codes which is entirely understandable as they are codes for the thermistor not reporting an adequate heat level.
Fusing section not heating aside, in Service Mode, when I attempt to do anything I am prompted with "please wait 3901 [or 3801]" and becomes unresponsive. Obviously, I cannot flash the firmware via USB at this point and internet ISW is not possible as the controller is not fully engaging (if at all).
I have physically checked the entire fusing unit, PRCB and wiring and everything looks okay. I would check the Fusing Power Board (FPB) board, but Konica's documentation seems to be lacking so I have yet to locate it to inspect it.¿
I performed the CF card recovery (10.0_Base) just for the hell of it...no change
I have considered a bad heating lamp causing a circuit break to all four bulbs, but not sure if one heating lamp will cause all others to fail and I doubt all suddenly burned up (if any)--perhaps someone smarter than me can clarify?
Running out of ideas other than replacing boards--simply wrapping a web roller shouldn't destroy the FPB or PRCB...
