View Full Version : Minolta c450 c-d370
geltrons
11-05-2013, 07:05 PM
good day to all
have a minolta c450 , after a power failure displayed c-d370. rested the machine using stop-0-7-1-3-9.
after restart displayed japanese language, changed the marketing are, displayed enter serial number and
upon entering machine is ready
now my problem is, while registering the IP address machine as for reboot and the entered IP address is
vanished. DHCP setting, Auto IP is always turned on after reboot. also not aquiring IP
Your help is needed
regards
Thomson
gibo
11-21-2013, 08:56 PM
have a konica minolta.when i power on the machine,it reboot many times.sometimes when the machine is a copy mode,when you press START bootton,it reboot again.please help me to solve this problem.waiting your reply.
thankyou
gibo
11-26-2013, 12:29 AM
hello sir
my konica minolta 450.when i power it ON,the touch screen will come on for some few seconds then went off,while the machine is ON.
PLEASE I need you help to tell me solve this problem.
even i press the reset keys,thhe machine cannot steel work. thankyou
Synaux
11-26-2013, 01:23 AM
good day to all
Your help is needed
regards
Thomson
Do you still need help with this? I am pretty sure you need to run the NVRAM recovery firmware and execute the NIC reset. "For C450/C351: 20070301_4037-F000-Gcn-G4-000(00)_CHECKSUM-29F9.EXE"
TNBT0700091EN00
gibo
12-01-2013, 02:14 PM
hello sir
have error code d-203.
when power on the machine is show the above code.
have done trouble reset,but steel not working.
let me know where is the problem
an have a solutution to this problem.
it very urgently.
thankyou
Synaux
12-02-2013, 06:45 AM
hello sir
it very urgently.
thankyou
Are you an end user or a tech?
If you have access to KM firmware, I suggest you perform what I outlined in my prior post.
RRodgers
12-02-2013, 06:34 PM
Make a new thread and stop hijacking an exsiting one!!!!
gibo
12-04-2013, 12:22 AM
hello big boss
am just a USER of konica minolta
but if you lead me the way to solve this problem,sure i can try
your help will be greatful to me
waiting your kind reply
thankyou
sholly
08-12-2015, 01:46 AM
hello,
please what are the step to take in NVRAM recovery. i am using c351. please i need your help
