Cannot turn off "Auto" in Obtain Setting on PCL driver
  • patk
    • Jun 2008
    • 56
    Hi All
    Bizhub C284 - web interface going offline regularly so I want to turn off Auto in the "Obtain Setting" on the Configure tab on the PCL driver (3.1.1.0). Client has Windows 7 Pro 64 bit and I untick Auto, set the Finisher option manually and OK out.
    As soon as I go back in it is back on Auto and the Finisher has gone.
    What could the problem be
    Cheers for any assistance
    Pat
  • Dougtech
    • Apr 2011
    • 113
    Re: Cannot turn off "Auto" in Obtain Setting on PCL driver
    Don't know if this applies, but very often I have had to go to the ports tab, configure port, and uncheck the SNMP box. Was causing a bunch of my clients issues where the printer icon would gray out at times and go offline and other setup issues.
    Is now my default setup to turn it off.
    • Synaux
      • Mar 2012
      • 1224
      Not sure...
      Did you try reinstalling the PCL drivers?
      Try using PS drivers
      Can you replicate this on another computer?
      • patk
        • Jun 2008
        • 56
        Thanks for the suggestions
        SNMP already off in Port Monitor
        PCL driver reinstalled twice.
        Its happening on more than one PC. Also Auto is not finding the finisher and if added manually will disappear again when next look at Printer Properties
        • Dougtech
          • Apr 2011
          • 113
          Is the driver installed locally to each PC or shared from a server?
          Does the user have "print management" or "manage this printer" rights for the printer? (located on the "security" tab)
          • speedtek
            • Apr 2013
            • 46
            Did you ever get this issue resolved? I have a customer with the same problem. When we uncheck "Auto" on the server and hit OK, it is rechecked when we go back into the properties. This is preventing us from enabling pass-through authentication for Account Track.
