bizhub c351 touch screen problem
  • alejandro
    • Mar 2008
    • 33
    Hi all,
    I am having a problem with a bizhub c351. The touch screen does not work.
    the machine seems fine, but the touch doesnt work. Can anybody help?
    thanks
  • just a tech
    • Jan 2007
    • 332
    sounds like ya need another touch screen.. best advice i can give ya is to call a service tech.. good luck
    • alejandro
      • Mar 2008
      • 33
      How can I take it apart? I remove all the screws but I still couldnt not do it. any advise on how?
      thanks
      • random
        two screws on either end of the control panel behind rubber bungs
        • mitchl
          • Apr 2007
          • 501
          A rubber bung huh!................ I had a girl friend once who enjoyed her rubber bung, god I miss her!
          The real question is what is this person going to do once he gets the touch screen apart, wave a magic wand to fix it? Call a tech to fix the machine you are just adding insult to injury by dissecting the poor thing and possibly doing more damage which could increase the overall repair total........... Remember, if all else fails leave it the hell alone and call the A team in to fix it.
          • mikeena
            Branch Technical Manager
            • Mar 2007
            • 220
            before you go doing all that try this. thurn off machine. turn on main power. once that is done hold down the utility key and turn on sub power. trouble reset will appear see if the screen works now
            • alejandro
              • Mar 2008
              • 33
              Hi all, I opened the screen and SOME part of it worked. It seems that some part of the screen is frozen or something. Ill try to restart the machine. The reason that Im trying yo fond advise by myself is that in this country I cant find support for this machines. I just moved back here to start a small biz and I dont know my way around much yet.
              thanks
              • random
                ummmm, reset the ribbon connectors...problem fixed.
                • alejandro
                  • Mar 2008
                  • 33
                  How do I reset the ribbon connectors?
                  thanks
                  • DCPS
                    • Mar 2008
                    • 116
                    thanks
                    The red one goes to touch screen and the blue one to the machine. I don't think though, that reseting this will solve your problem but you can give it a try.
                    • ebm
                      • Apr 2007
                      • 183
                      I hope you tried to perform the "touch panel adjustment" in the Accessibility mode before you decided to take the panel apart.
                      The touch panel sensitivity may only have needed adjustment.
                      Page 4-33 of the Copy Operations Guide or page 160 of the Field Service Guide. Hope you didn't f*** things up for nothing by trying to disassemble the panel.
                      • mikeena
                        • Mar 2007
                        • 220
                        yeah that would cause some issues. thats why i was saying just try the trouble reset i believe it bypasses and dont need adjustment. but hay now you know how to do it. lmao
                        • alejandro
                          • Mar 2008
                          • 33
                          Thanks to DCPS, my machine is now working fine. It took a couple restart, but everything seems to be working fine. I think the (OK) butting kind of dont work from time to time, but other then that its all good. I will post any changes.
                          thank you all for your help.
                          • alejandro
                            • Mar 2008
                            • 33
                            Hi all,
                            Finally it seems that the touch panel gave up or something. One day it just stopped working and its not responding. I also tried to clean the waste toner box and after I putted back in, I got an error C-3451. I think I could get it back to normal by restarting the machine, but the problem is the Touch screen not working now.
                            any advise?
                            thanks
                            • nmfaxman
                              • 1702
                              Try doing the touch screen adjustment. RTFB
