View Full Version : konica 250 fax problem
DOE
11-15-2013, 10:08 PM
installed a used bizhub 250 monday. fax worked fine first 2 days then they no longer recieved any. tried from a office next door and i could hear 250 beep when they sent it but nothing came out of machine. the cofirmation report on other end says fax was sent successfully. i noticed that machine says 97% memory. could it be storing faxes in memory and if so why did it just start doing that and how do i change it so that it prints them out instead of storing them if thats whats going on. thank you for any advice i do get dial tone when i go off hook
JustManuals
11-15-2013, 11:59 PM
http://www.justmanuals.com
Paul@justmanuals.com
copier addict
11-16-2013, 01:49 AM
Is it looking for a specific size of paper to print the faxes on?
wseyller
11-16-2013, 04:35 PM
Make sure fax forwarding isnt turned on. Been a while since I set it up on this model. But if it is set to not print the fax even when a fax forward fails you might see this behavior. Though if set to print report on tx failure you would see a report print from a fax forward failure.
Sent from my DROID BIONIC using Tapatalk
