View Full Version : kyocera km-8030 error C4200 after changing the new laser unit also
kibbs
11-16-2013, 08:18 PM
Dear Friends,
i am posted in the forum regarding this same problem.. i am order and fix the new laser unit.. then also i am getting the C4200. Mr. Blackcat i really appreciate his guidenance.. Today i replace the main charger also after i am taking 450 continuos copy then also i am facing the same C4200 Error on Km-8030. sometimes lining appearing that copy it seems like charger lines... but i am fix the new charger..
JustManuals
11-16-2013, 08:22 PM
http://www.justmanuals.com
paul@justmanuals.com
A worn / bad / dirty DV ground contact at the rear frame assy' can cause the same code.
blackcat4866
11-17-2013, 12:19 AM
You were correct in trying the primary charger, and Geo is also correct with the developer bias contact. To take that a step further, any charge related arcing can cause the C4200 error.
http://www.copytechnet.com/forums/showthread.php/82826-kyocera-km-8030-error-C4200?p=386700#post386700
Any kind of high voltage arcing can give you the C4200 errors. See below:
"C4200" error message, 163 times. Clears. Arcing primary charge unit. Replace primary charge unit. Also may need drum replacement.
"C4200" intermittently. Error clears, then returns after a few copies/prints. Transfer charge arcing at the ground contact causes logic errors. Rebuild/replace transfer belt assembly (302FB93061). See QA Service Bulletin 7393.
"C4200" intermittently. Error clears, then returns after a few copies/prints. The laser unit harnass has been re-routed, as in later production. Install new style laser unit harnass per QA Service Bulletin 8619.
"C4200" intermittently. Error clears, then returns after a few copies/prints. Pre-transfer corona cleaner becomes jammed, shorting the pre-transfer charge. Repair/replace the pre-transfer charge unit.
"C4200" intermittently. Error clears, then returns after a few copies/prints. Developer bias arcing at the imaging unit contact causes logic errors. Replace developer bias contact.
"Copying Stopped 4200" or "Turn Power Off/On 4200" intermittently. Error clears, then returns after a few copies/prints. No error is stored in the service error log. Developer bias making poor contact at the imaging unit contact causing logic errors. Clean any conductive grease from the developer bias contact.
"C4200" & "C0630" intermittently. Error clears, then returns after a few copies/prints. Paper outputs face up to tray B regardless of default settings (can be temporarily reset with U906 partial reset). Developer bias arcing at the imaging unit contact causes logic errors. Replace developer bias contact (302FB08481).
kibbs
11-23-2013, 07:02 PM
thanks a lot Geo ..!! Your Advice help me lot..!! its grounding issue somewhere.. I reconfigure the wiring and service complete machine with reference of another machine... its works fine.. at the time i take 5200 copys continuosly..!!
kibbs
11-23-2013, 07:03 PM
thanks a lot Blackcat ..!! Your Advice help me lot..!! its grounding issue somewhere.. I reconfigure the wiring and service complete machine with reference of another machine... its works fine.. at the time i take 5200 copys continuosly..!
blackcat4866
11-23-2013, 11:37 PM
Congratulations. So it was the laser wiring modification? =^..^=
kibbs
11-24-2013, 04:58 AM
somewhere grounding issue i found in the board and developer grounding..!! apart from that i think everything seems okay..!! then i serviced...
