Bizhub 751 ATDC sensor adjust
  • rocky_biskit
    • Jun 2009
    • 76
    I just did a DV change and I have the info on getting into the tech mode. I cant seem to figure out which menu to be in, to execute the F8. Any info would be helpful.
    Thanx.
    • 14406
    Re: Bizhub 751 ATDC sensor adjust
    There is not an ATDC sensor on this machine. You have to run "drum peculiarity". Start with "cartridge set" then do the rest in order excluding "LD bias"
    Hope this helps
    • rocky_biskit
      • Jun 2009
      • 76
      Hope this helps
      Thanks ... that explains why I couldnt find it. How many steps are after the "cartridge set"? Also, the customer had used the machine already and it got overtoned. Will I need to replace the dv again or will the drum peculiarity procedure take care of it?
      • minimerlin
        • 851
        If the machine has been used and has become overtoned, then the answer is Yes, you have to change the dev again as you will not be able to do a proper set up. Make sure you get rid of all the recycle area toner as well as cleaning of the drum density sensor, before loading new dev and doing the drum peculiarity adjustments.
        Please do not PM me without asking first.
        • rocky_biskit
          • Jun 2009
          • 76
          Thanks again!!! You have been very helpful. I hope that one day I may return the favor!
            • 14406
            These things over tone, it is just their nature. Before changing the dev, I would try running a bunch of skyshots to deplete the toner and then run the drum peculiarity. As stated before, there is no ATDC sensor. Density and T/C ratio is determined by patches on the drum. (not a great method).
            So, just because it is over toned doesn't mean the dev is destroyed.
            Hope this helps.
            • rocky_biskit
              • Jun 2009
              • 76
              Hope this helps.
              Excellent!!! I was actually gonna try that anyway
              Thanx!!!
              • JustManuals
                • Jan 2006
                • 9838
                paul@justmanuals.com
