View Full Version : C550 Jam indicator at Paper Exit
AlSyed
11-23-2013, 01:46 PM
I have a C550 with very low mileage (15k, Show room). I have a jam indicator at screen at paper exit (In service mode it shows as "1"). Replaced Paper exit sensor at the right side door but jam is still there. Please help me to find out what I am missing.
JustManuals
11-23-2013, 05:42 PM
http://www.justmanuals.com
Paul@justmanuals.com
dirtyfingers
11-24-2013, 08:02 AM
Try cleaning/replacing the one way clutch at the turnover/exit section
xscotty1990
11-24-2013, 10:57 AM
Hello,
do you have upgraded the firmware?
There normally is a black cover on the sensor, is this cover still there?
Greetings
Marco
minimerlin
11-24-2013, 11:13 AM
make sure that the exit sensor actuator is working correctly, it can stick in the operated position or not swing back far enough if the sensor mount is bent!
AlSyed
11-25-2013, 04:21 PM
Hello,
Greetings
Marco
Tnx Marco, I don't know if the firmware was upgraded. Black cover is there as well.
AlSyed
11-25-2013, 04:24 PM
I push the sensor while kept the side door open and then swing the flag that goes in sensor but it did not change. It is swinging freely. Home position as I see. Flag stays between Sensor.
xscotty1990
11-25-2013, 04:32 PM
Did you also changed the photo interrupter?
The same interrupters are in the LCT's.
You can take them for testing.
greets Marco
