View Full Version : dedicated surge protector...
SmellsHot
12-02-2013, 08:42 PM
Not sure what everyone calls the plug, but we call it a dedicated 20amp......Basically it's the one on the Konica 554e. It has one vertical and one horizontal and a ground.....
I cannot find any surge protectors for these.....We use to use isobars....
Any suggestions?
Ctl-Alt-Del
12-02-2013, 08:53 PM
Any suggestions?
I've been buying from ESP for years, they will have whatever you might need: http://espei.com/products/esp-digital-qc/
Synaux
12-03-2013, 01:07 AM
Any suggestions?
This (http://www.google.com/imgres?imgurl=http://www.showmecables.com/images/catalog/product/Nema-5-15R-Or-Nema-5-20R-To-Nema-5-15P-Power-Plug-Adapter-1.jpg&imgrefurl=http://www.showmecables.com/product/Nema-5-15R-or-Nema-5-20R-to-Nema-5-15P-Power-Plug-Adapter.aspx&h=266&w=400&sz=13&tbnid=LeRmcRyPUJYGjM:&tbnh=90&tbnw=135&zoom=1&usg=__mBOdILbS9vtdgDu8_3m7AveOshM=&docid=eBs8na21l8d_9M&sa=X&ei=sy2dUpeTE8as2wWJnICwAQ&ved=0CFAQ9QEwAw)is the plug you are talking about right (Nema 15-20r)
I simply order the adaptor I posted and use the typical ESP protectors.
Hope that helps...
blackcat4866
12-03-2013, 01:15 AM
5-20R? Like this:
23144
Use ESP D91424T:
http://www.ebay.com/itm/ESP-D91424T-20A-120V-Transient-Voltage-Surge-Suppressor-AC-Kyocera-/121150704960
tmaged
12-03-2013, 02:03 AM
http://www.memoryexpertsinc.com/products/mx-power/
They have these in 15 & 20 amp models. They're affordable and pretty dang cool. Call Todd Emery for pricing.
We've started using them and have been very pleased.
mmru4real
12-03-2013, 02:24 AM
Todd is great to deal with and if you order over a certain amount you get a nice discount also!
SmellsHot
12-10-2013, 12:49 PM
Thanks everyone for the suggestions......
Frostwolf
12-10-2013, 08:56 PM
We stop using the ESP, the older models were passing electrical noise into the Fax lines when connected to C353 series.
We went to SmartPower filters here ... http://www.smartpowersystems.com/content/products/computer-gradefilters/copierguardianII/copierguardianII.html
Smart power has been pretty good, a few have failed with noise problems.
Innovolt's have caused an issue when the power drops out, and caused our machine to lock up.
I will look into those MX Power brand, those look nice.
ZOOTECH
12-10-2013, 09:24 PM
We stop using the ESP, the older models were passing electrical noise into the Fax lines when connected to C353 series. We went to SmartPower filters here ... http://www.smartpowersystems.com/content/products/computer-gradefilters/copierguardianII/copierguardianII.htmlSmart power has been pretty good, a few have failed with noise problems. Innovolt's have caused an issue when the power drops out, and caused our machine to lock up. I will look into those MX Power brand, those look nice.
The older ESPs didn't work on GFCI circuits either.
nmfaxman
12-10-2013, 11:45 PM
You can make a pigtail connector in the meantime.
Female plug matches output plug of machine, male plug matches suppressor.
Use a thick AC wire to avoid heat problems.
