View Full Version : Ricoh 2045esp pcr setting is changing
Rick
03-11-2008, 01:48 AM
After installing new drum blade and pcr I set the ID sensor and initialized the developer. The pcr voltage went to 1500 but the copy showed marks in the middle of the page. When I adjusted the pcr voltage manually to 1650 the copy is fine . Later I was informed that there were marks again on the copy and I discovered that the pcr voltage readjusted itself to 1500 . Is there a way to keep the pcr set at 1650.
Scott_Lewis
03-11-2008, 03:51 AM
Although I'm NOT recommending it, I think what you need to change is SP2005. Specifically 2005-3.
The longer I work on these, the less I mess with the process settings.
