View Full Version : Di 351 jamming on fusing unit
goldencup
12-11-2013, 01:15 AM
Hi, i would like to ask if you could advise me what are possible cause or parts maybe to replace on the machine Minolta Di 351. The problem is paper jam on fusing unit using all paper tray. Thank you very much.
Hansoon
12-11-2013, 03:38 AM
Very likely exit sensor in the fuser unit. Sometimes the drive motor of the duplex unit in case the machine has one.
Hans
goldencup
12-11-2013, 06:44 AM
Thank you for the reply Sir Hans, nice to hear from you again :). I've check the fusing section, maybe it's in the duplex area that i need to check.
Thanks again.
Hansoon
12-11-2013, 08:22 AM
Good to see you too Mr. Ng, did you replace the exit sensor itself? I mean the photo sensor, not or not only the flag.
Hans
goldencup
12-28-2013, 05:02 AM
[SOLVED]
we found out a slightly cut wire while tracing the line of exit sensor that's why sometimes it's okay and sometimes it's not.. :-)
