View Full Version : Miscellaneous Bizhup c360 user box switch
khaled_abosere3@yahoo.com
12-15-2013, 02:33 PM
First problem we have faced is the copied paper have lines along the page we solved the problem by repeat the sequences of installing the machine but during solving the problem our engineer doing the following process :1-service mode2-system 13- initialization clear all datathen the user box switch not worked when we press it the LCD does not changed and we can not to make any scan with any original.
JSC
12-15-2013, 02:46 PM
You need to turn the hard drive back on.
12-15-2013, 02:53 PM
Thank you very much.
Yes we have turned on the hard drive as:
1-service mode
2-system 2
3-HDD was uninstalled
then make HDD install and machine worked scanner well.
again thank you for your cooperation.
