View Full Version : Miscellaneous can isopropyl alcohol be used for safely cleaning drums
kowloonkid
12-16-2013, 10:55 PM
Hi guys, can someone tell me if i can use isopropyl alchohol to safely clean the drums on my konica minolt
a c5500?
seeb
12-16-2013, 10:59 PM
I have done it many times with no apparent side effects.
kowloonkid
12-16-2013, 11:09 PM
thanks for a quick reply! :p
Tonerbomb
12-16-2013, 11:57 PM
a c5500?
I don't work on the KM machines, But on the Ricoh's sharps ect. I'll use it to get sticky stuff off the drum. To clean and polish a drum I use NUFINISH car wax, also on Ricoh's hard charge rollers..
JR2ALTA
12-17-2013, 01:02 AM
Alcohol is fine, just careful your rag isn't abrasive
blackcat4866
12-18-2013, 02:09 AM
Yes.
Other choices that do not damage drum coatings:
Dispersant
Paraffin Lamp Oil
Orange-Sol
But all these cleaners are oily so you need to rinse the drum with alcohol when you're done. And I'm beginning to think that the Paraffin can absorb into polyurethane ... like drum blades, so make sure Paraffin does not contact the drum blade. =^..^=
wseyller
12-18-2013, 02:41 AM
Depends on the drum. Years ago I used to recoat drums and some of them would crystalize after time when apply isoproply to them. Normally those particular drums were crap anyway.
Sent from my DROID BIONIC using Tapatalk
CompyTech
12-18-2013, 03:52 AM
I've cleaned them with alcohol before. I've also used brillianize before.
Phrag
12-18-2013, 06:12 AM
I used Rum- I mean ALCOHOL to clean off tape residue from a brand new C452 transfer belt. Nice packing KM.
Synaux
12-18-2013, 07:26 AM
Yes.
Dispersant
Paraffin Lamp Oil
Orange-Sol
I agree with the Paraffin--in the past, I have actually researched paraffin while fabricating a surfboard--its applications are vast and might surprise.
Anyways, regardless of safely applying anything to the drum, one should ensure that little/no reside will reach the blade.
Ray G.
12-22-2013, 04:20 PM
No problem on the alcohol, but do remember to use a lot of padding powder.
mitchl
01-20-2014, 07:04 PM
Alcohol is fine just make sure its 99% isopropyl.
