Hi Guys,i'm seeing a streak of black toner going down the side of my page, i was wondering if one of you great gurus can shed some light on this, much appreciated.
Is this a transfer belt problem? (konica minolts bizhub pro c5500)
Re: Is this a transfer belt problem? (konica minolts bizhub pro c5500)
Hi,
Could be either transfer or drum cleaning failure. If the toner on the page is black only it will be drum, if it is a mix of colours it wil be transfer belt cleaning failure.
Hope this helps -
Paul@justmanuals.comComment
If that black area is from lead to trail edge of the paper it sure looks like a failed developer unit to me.
As bad as that one is you should be able to see something if you remove the transfer belt and drum to look at the magnetic developer brush in the dev unit.Comment
12-18-2013
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
First of all, what is the paper set up regular or R, if R i would say it's drum, but could be all that mentioned above. More info needed to determine exact problem.Comment
swap the charge units and take a close look at the black DV-unit.Comment
