View Full Version : KM 1200
CT Copier Repair
01-02-2014, 11:53 PM
the PF703 showing a c-0263 error
Help
new machine for me I know is a big boy machine but I work on the big Xerox and canon boxes
Brian
it will load and feed a few sheets then throw the error
gurko_gg
01-04-2014, 12:09 PM
Hi
separate the pf unit and check the feed way for jammed paper
if you can try the pf drive board.
or you can disable tray 4 following steps
Service mode - system setting- software dipsw settings- "18-3=1"
Regards.
Gürkan.
Mick01
01-06-2014, 11:03 PM
Hi,
You have an issue with M11 shutter motor in the paper feed suction section. Try swapping the suction section with another tray and see if the fault code changes. If it does you have a faulty motor. If not i suspect either a wiring issue or the PFU driver board.
Hope this helps.
