View Full Version : konica minolta bizhub 652 drum unit replace message
Please Dears,
How to reset drum replace message for Konica Minolta bizhub 652
Thanks in advance
frankencopier
01-06-2014, 06:05 PM
Obvious part first - have you replaced the IU?
JustManuals
01-06-2014, 06:12 PM
http://www.justmanuals.com
Paul@justmanuals.com
Thanks for your kindly reply
I did not change IU, the copy quality is good but I want to remove the message only.
I had the same problem with bizhub 600 before and I cancelled the message, but I can not do the same with bizhub 652.
regards
SmellsHot
01-07-2014, 12:50 PM
change software switches
Synaux
01-07-2014, 06:00 PM
This model doesn't need the special firmware, right?
emujo
01-07-2014, 09:38 PM
Incorrect, you must install the firmware or the needed changes to the soft switches will not take. Emujo
