Can anyone help me with error codes at start up on my Konica C7000, PLEASE??? I am getting error code 4502, 3201, 4634 or 2824 while starting up. I did try it 'Print Mode' and it works fine but when I switch back over to regular mode it bombs. Any ideas anyone???
C7000 Crashes at start up = Error codes 4502 & 3201
Mike HortonTags: None
Mike Horton
Re: C7000 Crashes at start up = Error codes 4502 & 3201
The machine has been down for 2 days now. I can get it to print in test mode but it crashed in regular print mode.Comment
Hi,
Your machine seems to have serious issues.
My best guess is you have an issue with your transfer belt unit for most of the codes. Could also be related to the colour registration unit being dirty.
3201 is not a fault code. i assume you mean 3102 which is related to the fuser one way gears slipping.
What are the consumable lives (drum, dev, charge units, transfer belt unit). Are they due for replacement?
Hope this helps and good luck.Comment
