View Full Version : Miscellaneous Strange banding along the side
kowloonkid
01-14-2014, 10:25 PM
23591can one of you great gurus give me some insight , its only the black that does this. much appreciated!
bizhub1
01-14-2014, 10:52 PM
How about make,model ?
blackcat4866
01-14-2014, 11:00 PM
I'm going to make some WAG's that this is a copy, not a print, and from the glass, not through the document feeder ... true?
If true, the document feeder height may be out of adjustment, letting the original float up above the surface of the glass. =^..^=
PeterG
01-14-2014, 11:54 PM
I will take a punt on it being a C451, with badly grounded K image unit.:)
Synaux
01-15-2014, 01:12 AM
Yea, or perhaps a mirror in the scanner is out of place or bent housing.
gurko_gg
01-15-2014, 08:04 AM
What is machines model?
i think c6000
regards
Gürkan
blackcat4866
01-15-2014, 11:04 AM
i think c6000
regards
Gürkan
You think? You're asking for help and you haven't even determined what model it is? =^..^=
gurko_gg
01-15-2014, 12:49 PM
Hi,
I have 117 bhc6000,6500,7000,70hc model machined in the field.
I saw that problem on the c6000. I asked modelfor that.
Records
Gürkan
kowloonkid
01-15-2014, 02:13 PM
this is on a konica minolta c5500, not sure what the problem could be it's kinda intermittent , sometimes when i change the paper size i don't see any black toner residue. transfer belt issue or a drum blade problem?
gurko_gg
01-15-2014, 03:16 PM
You have distance problem between drum and developing unit. Make the following steps for countermeasure;
1. Remove K dev unit and clean them.
2. You will see two yellow whell.
3. Paste orange tape to whells for expand distance.
4. Reinstall dev unit, make gamma adj.
Regards
Gürkan
