View Full Version : CQ C652 missing print
Hi
i have problem with C652 ,the transfer belt and roller have been replaced but problem persists
any help appriciated
see attached image of C Y M K halftone images A3
EarthKmTech
01-17-2014, 08:55 PM
you need to do the stop test to determine where the problem is actually occurring.
blackcat4866
01-17-2014, 10:37 PM
Ditto that. Run those images ledger/A3, then pop the door open when it's just reaching the fuser. Logically it's got to be primary or secondary transfer. Does the developed image on the primary belt look good? Does the unfused image on the paper look good? =^..^=
JustManuals
01-17-2014, 11:39 PM
http://www.justmanuals.com
Paul@justmanuals.com
RRodgers
01-19-2014, 10:06 AM
Is your waste box full of gritty stuff?!?! Looks like you've lost dev on ALL your IU's. How are the HV connections on the machine? I'd check them and be sure that they are clean. I'd be willing to bed you might have a HV unit that is going out and pulled dev.
Fixed should have spotted it sooner
rear arm of transfer roller holder broken underneath
copier tech
02-01-2014, 09:08 PM
I had one of those break last week, I repaired the broken part with a cable tie. What item did you order to fix this?
Hi
The rear arm is A0P0710501 and the one it goes through is 4036471201
copier tech
02-02-2014, 07:42 PM
Hi
Cool thanks, how easy is this part to replace BTW?
Easy to fit 1 circlip on arm and 1 spring on part it goes into
copier tech
02-02-2014, 09:42 PM
Thanks, i'll order this part & replace next visit
EarthKmTech
02-02-2014, 10:09 PM
these seem to snap all the time, I carry them in my car - still happens with the 654e / 754e too.
