methogod
01-19-2014, 01:32 PM
Ok, so long and the short of it...
was happening alot, swaped duplex motor with exit motor and it go much better, thinking the motor was had a weak/flat spot or somethign, maybe just taking it off and putting back together helped.
Seemed fine for a while, but now i get it only when the machine prints (not on startup/wakeup) it will print till finisher is full, when i unload and or reload paper, the printer does it adjustments, most likely density adjustments on these longer runs, while this happens the cam opens to take pressure off the exit decurling roller.
When the machine is ready to print as soon as it cam's closed i get the C-0213 code. Now i found a little work around, after refilling paper or unloading finsiher, as long as i hit start, let it start the adjustments, then open the feed tray, it will wait for "ask" for paper, then i can close tray press start again and most of the time this works.
So motor has been replaced on exit, sensors look good and clean, swapped them as well just to see if the error stays on PS10 or moves to PS13 (which are C-32XX) errors... That has yet to happen... so its not the sensors (unless its the harness)
So next i guess are the gears and bearings/bushings
Since i can duplicate it most time, i can hear it cam'ing closed but not fast enough...
have been suggested to clean the gears, one ways etc.
any one see this and know where to go next? thanks,
