Cosminake
01-20-2014, 09:32 AM
Hi,
I've mounted VI-504 with relay board, then the Fiery IC-409. I've changed to Controller 1 in service mode.
I can access the fiery's web interface, but on the machine, under Utility menu, the option no. 5, Controller details, does not appear.
I can connect to Fiery via CWS5, but I cannot print anything.
I used method B of mounting, one LAN cable from router to Fiery Controller, one crossover cable from controller to copier.
The Fiery code is "00", it seems that it hasn't any problem.
On the machine, administrator settings, network settings, tcp/ip auto, the auto ip allocated is 172.17.249.2 with subnet 255.255.255.248 and default gateway 172.17.249.1.
I've attachet a print screen from web interface.
Thank you
Thank you
