brianho80
01-22-2014, 05:41 PM
Hi guys,
Anyone of you familiar to this problem before?
At the beginning, I try to service (k) drum unit, clean up developer, drum, blade and contact points but problems remain the same..
Second attend, I replaced (k) IU unit, hopefully can solved but no luck. There after, i suspect transfer roller and replace with another used unit (good unit), however problem remains the same.
lastly, I access service mode, change transfer value setting by adding it. Shadow had gone and my print out didnt effect much like blur or having background.
Anyone has better solution or know the why??
Aprreciate for your sharing..
