View Full Version : Turn the main switch OFF and then ON following the instruction.
jimmyisec
01-23-2014, 06:29 AM
Hi, i have a problem with my copier konica DI 470. when i turn it on, its giving a message on screen the message is: Turn the main switch OFF and then ON following the instruction. after a wait nothing can happen. machine is still hang on this message
23650
jimmyisec
01-23-2014, 01:34 PM
23650
NO One know on technet forum?
mo0651
01-23-2014, 02:02 PM
If you are using the main switch on the left side down by your knee, then I would unplug from wall. Wait a few minutes and try again.
hotfuser
01-23-2014, 03:33 PM
i think the problem you have got is that the copier has the wrong controller type set in tech rep.
If you perform a memory clear this resets it too type '0'
If it has a Pi 4700e you need to set it to o '6'
I hope this helps.
jimmyisec
01-25-2014, 06:40 AM
I hope this helps.
machine is di470, not pi470
jimmyisec
01-25-2014, 06:43 AM
I hope this helps.
Thanks Bro. Problem Solved :):D
darry1322
01-25-2014, 02:49 PM
The pi4700e is the printer interface not a reference to the copier. Glad you got it solved.
