View Full Version : CQ Kyoshiba CS 650c Smokey black background on bold black print
Xferunit
01-24-2014, 01:31 PM
I've attached an image of the problem for you to check out. It only happens on certain areas. Around the middle of the page, and the bottom of the page. Only on bold black print.
Tonerkiller
01-25-2014, 01:48 AM
Did you try swapping the drums.
Xferunit
01-25-2014, 10:49 PM
I sure did. Swapped the Y and K. No effect. Again, only on bold, large font, black jobs, and only in certain areas.
Xferunit
01-27-2014, 05:51 PM
Bump
ES-OGT
01-28-2014, 02:23 PM
A couple of ideas here:
1) Try different brand paper. It could be the paper can't handle that much toner and the fuser is smearing it.
2) Big and Bold may not work well for that model. I've got a customer with a 250ci that likes to do prints like that. Big black bold letters for signs. The problem is the machine can never get it as bold as they want it. Slightly different than your problem but may be the same reason. The machine can't handle fonts that big and bold.
Tonerkiller
01-29-2014, 02:30 AM
Maybe the fuser belt is worn
ES-OGT
01-29-2014, 09:03 PM
Good point. Whatever your problem is it's definitely fusing related.
