View Full Version : Error Code C3BO2 in c452
a-copy
01-26-2014, 07:17 PM
Hello,
I have this code in c452, any ideas for that?
copier tech
01-26-2014, 09:08 PM
Most likely failed fuser unit
JustManuals
01-27-2014, 02:45 AM
http://www.justmanuals.com
Paul@justmanuals.com
Synaux
01-27-2014, 04:09 AM
In addition to the fuser this might help 23685
hotfuser
01-27-2014, 11:47 AM
This problem is usually the IHPU failing. 9 times out 10 it is that but if it persists change the coil.
Damien Bates
07-07-2023, 05:22 AM
If you have tried troubleshooting the printer and the problem persists, it may be necessary to replace the IHPU. This is a common issue with printers, and replacing the IHPU is a relatively simple repair that can be performed by a technician.
In some cases, if the problem continues even after replacing the IHPU, it may be necessary to replace the coil as well. The coil is another component within the printer that can cause issues if it is malfunctioning. slope game (https://slopegame.io)
If you are not comfortable performing these repairs yourself, it is recommended to contact a certified technician who can diagnose and repair the issue for you. By doing so, you can ensure that your printer is functioning correctly and avoid further damage or issues down the line.
copyman
07-07-2023, 01:06 PM
You do realize the OP is 9 yrs old from 2014....
femaster
07-08-2023, 05:42 AM
Slipped in a SPAM link I see. I had you pegged from the start. ChatGPT using SPAMmer is all you are! Piss off!
