View Full Version : Miscellaneous FS-521 on C6501 states main try is full at 1500 sheets of 89gsm paper.
methogod
02-11-2014, 04:18 AM
Can not find any specific fix for this issue.
Seems like its the fiery that states it tray full before the engine does, but i cant find anything that has a fix for this.
Any one seen this...
let me know driving be crazy... should hold 2000 plus sheets, based on service and weight.
thanks,
Mr Spock
02-12-2014, 03:53 AM
The tray position sensor (Top) detects the incorrect position of the paper ejection paddle of Main tray. A firmware update is required.As a temporary countermeasure, open the front door of the finisher. The paddle is then rotated by initializing the FS-521 and the incorrect message is no longer indicated.
To prevent the message from reoccurring, please install updated Base firmware version A0GY0Y0-00N1-G00-40.
Faulty or malfunctioning paper exit level sensor (LED1).
Check the sensor in the I/O mode and replace defective sensor (p/n 13QJ 8551 0) if necessary. Please refer to Parts Manual pages, Item 38 on page 15
dljorg
05-21-2014, 05:38 PM
Have you checked the position of DIP Switch 3-7?
If it is set to zero the FS-521 tray capacity is 1500 sheets.
Set to 1 capacity is 3000
