View Full Version : Bizhub pro 1200 overtoning
CT Copier Repair
02-12-2014, 12:28 AM
PM done about 150 K drum dev cleaning blades grid filters etc
ran great then started to get a light grey band at lead edge now its dumping toner onto the transfer belt
Brian
JustManuals
02-12-2014, 04:34 AM
http://www.justmanuals.com
Paul@justmanuals.com
CT Copier Repair
02-12-2014, 12:02 PM
thanks paul
already have the manual
CT Copier Repair
02-12-2014, 03:43 PM
[QUOTE=CT Copier Repair;402726]thanks paul
already have the manual[/QUOTE
just got to machine and the developer is dumping everywhere
Development brush looks wrong. 8.5 mil on developer unit
drum scored customer pissed
developer unit is rotating so m3 is ok. Throws a c2202
checked everything there looks good
developer unit
drum
cleaning blades
developer
Anything else ?????
thanks
brian
Crowy79
02-14-2014, 03:24 PM
Hi Brian
I had the same issue recently, I found the developer had gathered in place scraping the drum and dumping the dev on the belt. I Fitted a brand new dev unit and made sure that when I tipped the dev and turned the mag roll it was evenly covered.
Hope that helps
Andy
scottybbb
02-15-2014, 12:58 AM
Had a bizhub 951 that did that.Took bar off just past mag. roller and cleaned under bar.Also tried to slightly re-form bar.May have to just replace developing unit.
