View Full Version : C284 /224
CrapAimer
02-18-2014, 12:39 PM
Trying to upgrade the firmware, when looking at the diagram it says take out the screw lift up the plate and insert the usb stick into the slot beside the cable, but when you lift the plate the slot is above it, is the cable in the wrong position ? machine straight out a box and working. any feedback would be welcome. Been trying the tech website bloody hopeless
Regards
George
emujo
02-18-2014, 01:18 PM
The slot that is uncovered when you lift the plate is the only slot that can take a firmware update. If there is anything in this port, remove it and plug it into any open slot (other that one designated as FAX 1 or 2). EMujo
MDR24
02-18-2014, 01:32 PM
Is it definetly a C224/224 and not a C224e/284e?...im pretty sure on the E series the slot is above the cable and on the original 224/284 the slot is beside?
CrapAimer
02-18-2014, 02:35 PM
thanks all I got it sorted
George
JustManuals
02-18-2014, 09:23 PM
George
George - Tell us what you did to solve it so that someone in the future with the same problem might be able to use it to help him/herself.
