Konica minolta c 6500 We are getting a darker band that is about 3/4 wide at the lead edge of the print 11x17 med/ heavy coverage simplex printed . After it runs 15 sheet or so id goes away. It isn't t the art work because if you rotate it is always on lead edge face down or face up. Any thoughts?
Band
Re: Band
Hi, Try this solution below. Note, this minimises the issue, not removes it completely
Hope this helps.
SOLUTION: Adjust the DC separation setting:1. Set Dip-SW 1-0 to 1.2. Select Paper setting => Change => Process Adj. => Separation DC (Front) and (Back).3. Change the Separation DC settings from -20 to -30.4. Please check the dark band level.
Re: Band
Hope this helps.
No wonder I have no hair!!!Comment
