View Full Version : Di550 error codes
stupidmachines
03-24-2008, 10:34 PM
Greatings and salutations sports fans. I can't find my manual and I need some info. They tell me the code is sc-13-5. I am going out there tomorrow and was wondering is anyone would happen to have some error code info they could share.
Thanks in advance.
cobiray
03-24-2008, 11:12 PM
Field manual doesn't have a 13-5. Closest one is 13F5 which is LD1 error. Troubleshooting section says to replace the print head or image processing board. I'd check the PH cables and see if the thumb screws were taken out yet, too.
cobiray
03-24-2008, 11:15 PM
From the solutions by model:
Description
The machine indicates trouble code C-13F5.
Solution
CAUSE: Incorrect installation of print head, PWB-Band/orincorrect LD bias adjustment.
SOLUTION: Please follow the steps outlined in attached Product and Technical Support Bulletin 3182 to confirm correct installation of the print head unit and
PWB-B. After this has been completed,perform the LD Bias adjustment outlined in attached Product and Technical Support Bulletins 3106 and 3426.
If the problem still persists and the steps in the troubleshooting guide advising the replacement of the print head (p/n 4002-0531-02) and PWB-B (p/n
4002-0102-15) have been followed, check the PWB-C. Afailed PWB-C (p/n 4002-0103-02)may also contribute to this problem.
Note : To view a PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from the Adobe® web site at:
Adobe - Adobe Reader Download - All versions (http://www.adobe.com/products/acrobat/readstep2.html)
nmfaxman
03-25-2008, 03:32 AM
There is no 13-5 service code or 13-5 jam code.
There is a 13-? for a paper feed motor failure or 13-? jam code that relates to a registration area jam.
The C13f5 relates to the newer Minoltas.
The DI550 is a Konica box.
stupidmachines
03-25-2008, 02:26 PM
Thanks guys. At least I have a direction to point now.
