View Full Version : DI 2010 noise when replenishing toner
rocky_biskit
03-03-2014, 11:16 PM
As the title suggests. There is a click/grind noise when toner is being supplied. I have seen the bottle lift up as it turns and then it seems to stop and starts clicking. The customer is using generic toner, but I am certain that is not the cause. Do these models have a problem with the drive gears wearing down or is it possible that the toner cradle is faulty. I had the toner cradle apart and did clean the plastic bushing but the problem persists.
Thanks in advance.
copier addict
03-03-2014, 11:21 PM
You need to order the toner add assembly. They bend the shaft that holds the bottle drive gear.
Hope this helps
fixthecopier
03-04-2014, 12:26 PM
copier addict is correct. You can just get the bracket and rebuild it, that takes an extra 30 minutes. It is major surgery. If you rebuild it, be very careful. I have gone behind techs who missed a clip and a gear wouldn't engage. You don't want to do this twice.
rocky_biskit
03-04-2014, 12:33 PM
Thanks, do you know what part of the parts manual that is found in. I looked at the toner hopper assy, and the rear frame. Cant find it in either.
fixthecopier
03-04-2014, 12:46 PM
Not off the top of my head. It is a bracket assembly, lots of gears and 2 solenoids, and the main shaft coming out, is what locks into the toner rotation cup. If you pull the toner drawer out and look in, you will be looking at the top part of it. Will have to remove finisher and rear covers,
It the manual it will show as a break down and as an assembly.
rocky_biskit
03-04-2014, 12:53 PM
Ok, I found the bracket. Does anyone know the part number for the assembly? I really do not want to rebuild this as it is in a womans home. The parts manual that I am looking at does not show it as an assembly. I think I found the braket on Precision ... http://www.precisionroller.com/search.php?q=4030-0214-02&x=19&y=13
Hansoon
03-04-2014, 02:27 PM
Precision ... http://www.precisionroller.com/searc...4-02&x=19&y=13 (http://www.precisionroller.com/search.php?q=4030-0214-02&x=19&y=13)
Phew...., that's a hell of a price for a piece of tin sheet.
BTW, don't forget to line up the rim of the protruding bushing with the frame of the machine. Been there done that....
Hans
(Photo should be turned 90° anti-clockwise. Could not modify attachment, don't know why.)
copier addict
03-04-2014, 11:19 PM
The part # for the assembly is 4030 0788 00.
Hope this helps
rocky_biskit
03-04-2014, 11:26 PM
Thanks !!!!! This will really help. I have a suspicion that it may just turn into a new machine sale now given the price.
