Can anyone help me out whit a Test chart (adf calibration page), my adf decalibrated by itself, in the first time it was cutting @ 2-3 cm from the top of the page , now it cut`s in half...
Thx
Thx
Just adjust it manually...I would be more concerned about why your machine "decalibrated" itself...
Are you talking about that A4 test chart that comes with every MFP for lead edge, auto zoom etc..? If so I can probably scan and send it to you, but you will have to print it on A4 for it to work properly. Emujo
Okay, thanks to emujo, I have finally recreated a pdf for printing this.
9J07-9551-00 ADF_TEST_CHART 9J07-9551-00.pdf
If anyone wants to take some time and measure an original to confirm my measurements are correct I would appreciate it.
This version is designed to be printed on a 11x17 and cut out to ensure that any printer placement variances are moot.
Outline box is set to A4 (297 x 210mm) for cutting.
Black bars are set to 20mm width for an outside dimension of of 287x190mm.
I reused emujo's scan for the arrows and text on bottom--I believe they are placed where they need to be.
I used my chart on one machine and it worked fairly well.
