View Full Version : Minolta Ep 1054
vaclav borc
03-26-2008, 06:48 PM
please help - did you anyone had service code C 0410 ,
exposure lamp light on in abnormal timing -
i have changed : exp. lap, AE sensor , this code appears once a 1 month.
Mark B
03-26-2008, 07:00 PM
Is the machine by a window? Is light hitting the AE sensor? Stray light is what causes abnormal timming codes on Minoltas
nilsonmorales
03-26-2008, 08:27 PM
i have the service manual if you need add me to your msn
nilsonmorales@hotmail.com
saludos desde el salvador
_SuabE_
03-26-2008, 08:37 PM
Checked the condition of your lamp cable, in EP1054 this usually worn out and gives you this error, this happened in 1/10 units i have. To make it sure do this trick turn off the machine remove the copy board glass so you can easily unplugged the AE sensor cable, then turn on the machine with the AE sensor unplugged, see the result if it will give you another error C041? the last number should be different not 0.
Goodluck!
Scorotron Wizard
04-26-2008, 09:39 AM
I've had this loads of times, its caused by sunlight hitting the exposure sensor when the operator opens the platten, it usually happens in the springtime when the sun is low in the mornings.
Cheers :)
Hansoon
04-26-2008, 08:03 PM
We had this often and it was always stray light as mentioned above. Hansoon
