View Full Version : Error Code Error 9401 bizhub 36 42 C35
Ros.g
03-13-2014, 05:15 PM
Hello, I solved the problem of the lamps of the 'scanner unit bizhub 36-42 - C35 and do not need to replace everything. The lamp is equal to the Triumph-adler DC-2128 "code : 302H994260" - orders two and modify the length of the cable on one of the two.
srvctec
04-28-2016, 07:32 PM
Why not just use the cable on the old lamp?
Ros.g
05-18-2016, 08:00 PM
[Quote = srvctec; 514888]? Perché non basta utilizzare il cavo sulla vecchia lampada [/ quote]
Ros.g
05-18-2016, 08:04 PM
hello, now no longer need to do this because it is available parts.
