View Full Version : Bizhub C352 Copies have faded lines only when scanning copies
creighhill
03-26-2014, 07:22 PM
I have a Bizhub C352 machine. When I print to the copier the quality print is perfect. When I scan from the top feed or flat bed scanner the copies come out with a faded area near the top of each page. See attached pic's. Please help if you can. Thank you, Creigh Hill
creighhill@gmail.com
245282452924530
copytechman
03-26-2014, 07:44 PM
This will likely come off sounding dumb but have you tried to clean the optics or white plate?
Regards!
A.
blackcat4866
03-26-2014, 07:49 PM
Regards!
A.
Ditto that. =^..^=
creighhill
03-26-2014, 07:53 PM
Yes I cleaned both. Thank you
blackcat4866
03-26-2014, 07:57 PM
Is it a particularly dirty environment? Perhaps the lens or CCD face are dirty? Just don't touch any painted screws. The focus adjustments are nearly impossible to replicate in the field. =^..^=
907tec
03-26-2014, 09:11 PM
I'm skeptical that this is truly only happening from the glass. Have you gone into service mode and printed off gradation pages for each IU? Does the defect also appear when you are scanning to email/smb?
copytechman
03-26-2014, 09:24 PM
Ok.... do the void areas move when you enlarge or reduce? That should tell ya a lot!
Regards!
A.
blackcat4866
Good catch, 907. The cyan image is developed just fine. This problem could easily be caused by a dirty laser slit glass, or a bad black IU. =^..^=
copytechman
03-26-2014, 09:27 PM
Which is why I asked if the void areas move (or not) when reducing or enlarging.
Regards!
A.
JustManuals
03-27-2014, 07:34 PM
This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
http://www.justmanuals.com
Paul@justmanuals.com
creighhill
03-27-2014, 07:38 PM
When I scan to email with the top feeder or flatbed scan, the copy is clear. No fading lines. Only when I make a copy it has faded lines. Any suggestions?
blackcat4866
03-27-2014, 07:44 PM
Please re-read these posts. =^..^=
907tec
03-27-2014, 07:50 PM
Print the CMYK gradation patterns. You will almost certainly see the same copy quality defects in the black pattern. Attempt cleaning printhead window. When that fails to do anything, go ahead and buy a new K IU. Cause that's all the problem is.
creighhill
03-27-2014, 07:54 PM
Thank you. I will try this now and report back . Creigh
