View Full Version : Electrical Konica Minolta C-203 Network Settings
Buddy with ACR
04-01-2014, 05:17 PM
My Network Settings choice on display screen is missing. Everything else is fine, can even print out configuration page. Need to input new addresses so it will print. Any help Thanks
Blizzoo
04-01-2014, 06:38 PM
Check if you have the correct Controller value in service mode 0 ->standard controller/ 1-if you use a firey
Try a NIC reset.
Buddy with ACR
04-01-2014, 07:20 PM
Try a NIC reset.
Where do you find the controller value in the service mode? Is NIC reset the normal trouble reset using utility key and power up procedure? Thanks
Albonline
04-01-2014, 07:51 PM
do you have a service manual? the info you are looking for is in it!
Blizzoo
04-01-2014, 08:41 PM
NIC reset must done with nvram recovery tool,must put on CF like a firmware update.
To view controller setting go in service mode->system 2->image controller setting.
Good luck
Buddy with ACR
04-01-2014, 09:12 PM
Good luck
Blizzoo The Image Controller Setting is also missing on my display screen. Where can I get a NVRAM recovery tool? Looks like I could use some luck. What next Thanks Buddy
Buddy with ACR
04-01-2014, 11:41 PM
The Image Controller Settings is also missing on my display screen. Where do I get the NVRAM restore tool? Thanks again Buddy
