View Full Version : Miscellaneous C552 Parts discontiuned (UK)
copier tech
04-12-2014, 09:57 AM
Anyone In the UK had this issue.???
Basically I wanted to order the lower right had door on a C552 as it was broken, & so were the front & rear hooks. (plastic)
However KM sent the door & the rear hook but didn't send the front hook, on the packing sheet it shows this part as discontinued!?
This machine is not that old, I've not had this issue on the C451 so why on this C552!?
The parts number I need is A00J 5737 01 Lock Claw /Front
jotunn
04-12-2014, 10:38 PM
According to the parts modification notice KOM111158E1 (https://bslj.konicaminolta.com/KonicaMinolta/showPMN.do?action=init&PMNNO=KOM111158&LANG=E) current part number is A00J573712. But you need to replace following parts as a set:
- Paper Feed Door/Lower (A00J571712)
- Attaching Cover (A00J574611)
- Lock Claw/Front (A00J573712)
- Guide Plate/Lower (A0P0571911)
- Guide Plate/Upper (A0P0571811)
- Ground Contact (A2X0568400) ----------Newly Made
copier tech
04-13-2014, 01:02 PM
Cheers for that. i've just found the revised manual!
copier tech
04-14-2014, 10:02 AM
By the way, can I just order the new front hook (A00J573712) do you know if it will fit the old panel!?
