View Full Version : Bizhub C352 - Entering fax numbers on computer
PeterSheoga
04-02-2008, 03:41 PM
We just got this machine, so I am still learning. I have many fax numbers I need to save in the machine's memory. Is there a way to do it from my computer, ideally by importing them from Excel?
Thanks,
Peter
NotByChoice
04-02-2008, 05:35 PM
You can put the IP if the copier into a web browser and setup in there. Like: http://192.168.0.55
PeterSheoga
04-02-2008, 05:39 PM
Yes, I just discovered that. Thank you for the reply!
Peter
pepper38_cnd
04-03-2008, 12:22 AM
Enter a couple addresses, then export the address book, Open the exported file in excel and then copy and paste your contacts and numbers into the excel sheet, being careful not to change the format. Save the file and then import it to the copier.
B0265
04-03-2008, 10:31 AM
you can also use the Data Amin Utility (it's on the CD). If you save the Excel fila as a csv file, you can import it using the Data Admin.
PeterSheoga
04-03-2008, 01:15 PM
Thank you, both. That will make things easier.
Take care,
Peter
