View Full Version : converting 220v c350 fuser to 120v fuser
richwalker
04-23-2014, 04:10 PM
Hi all,
Just checking if any of you brilliant techs have ever converted a 220v c350 fuser to be used in a 120v c350 mfp. I've got a customer that needs a fuser replaced and I've seen a couple of them under $300 on the web, but 220v fuser. I was thinking I could swap the connectors on the fusers to make it work.
Cheers,
Richwalker.
richwalker
04-23-2014, 04:30 PM
If anyone has a used fuser (120v) that I can get/buy with the thermistors intact that would be great.
Richwalker.
blackcat4866
04-24-2014, 12:31 AM
It's my understanding that it's the heat lamps that use either the 120Vac or 220vac. So if you kept the original modular connector, wire harness and heat lamps, you should be safe.
richwalker
04-24-2014, 01:51 AM
Thanks blackcat4866, thought about that but wasn't sure if the connectors were a factor or not. I'll get the 220v unit and swap out the lamps as it's the thermistor that's broken on the unit.
richwalker
ck1
04-24-2014, 05:09 AM
richwalker
If you machine is konicaminolta ( not oem like oce or etc ) .you can direct install. i have few unit from US version i just install 220v ok ( my location is 220V area ) . maybe you can try chk the PU auto convert or not .
copier tech
04-27-2014, 10:48 AM
Bit of a gamble this one & unnecessary, surely you can find a cheap 120v fuser online cheap somewhere!!???? even ask on this site!
http://www.copytechnet.com/forums/for-sale-trade-or-wanted/
richwalker
06-19-2014, 03:15 AM
Thanks all for the tips and suggestions. I bought a rebuilt unit online for less than 200. Got it 2 weeks ago and installed it in the C350 and it's all good now.
Thanks again for all the help.
Richwalker.
