View Full Version : C451 jamming
mrfuser
04-23-2014, 11:05 PM
C451 jAms coming out of fuser. Seems like the two white drive gears need replaced just past fuser before exit
Anyone know those part numbers?
907tec
04-24-2014, 12:05 AM
Gear 16T (1) - A00J 8946 00
Gear 16T (2) - A00J 8953 00
or the complete assembly:
Eject Drive Unit - A00J R726 00
rrrohan
04-24-2014, 12:49 AM
id also check the fuser drive gears and make sure there is no play in the shaft.
ive seen a few with the bearing that holds the shaft in position worn out allowing the shaft to move
not that its related to you problem but probably worth doing at same time as Exit Dr Unit if it does look worn
malthus
04-24-2014, 02:09 PM
exit drive bushing wears out causing poor meshing to drive to exit ,you can temporarly make a repair by turning the bushing through 180degrees but as this quite a long job it is better to replace the bushing when stripped down ,
