View Full Version : Bizhub 223
howard1234
05-01-2014, 10:55 AM
Hi I have got bizhub 223 keep getting c6103.scanner over run,also get sky copy's only through the document feeded,there ok off the glass have checked the sensor that's ok. Spoken to tec at Konica he said to change scanner relay board then mfpb still have the same problem.Even changed the document feeder now really stuck any ideas ?
SmellsHot
05-01-2014, 12:11 PM
Sounds like it's not homing properly. So either sensor, or faulty motor. After a power cycle, when the machine's going through its checks, lift up the lid and see how the scanner moves. It should go to the right and then back under the white reference guide....
