View Full Version : CQ Bizhub C224e Deformed colors-registration
DadO
05-01-2014, 11:02 PM
I have 2 machines confirmed doing this very strange problem from start of installation. One have 25 k and other 54k copes. It's getting worst and more often. Machines are installed roughly 10 months ago.
This issue it's not constant and it will appear randomly. Reports i got is that is happen most on larger paper sizes A3,SRA3. It happens when machine is printing lets say 100 pages. This problem will appear from page 50 to page 70 but it can happen from page 1 to page 100. It's totaly random. But most it happens when user replenishes paper in the middle of print yob, again randomly.
Link to sample. Page one - problem, Page 2 ( page 1 should look like page 2 :))
https://drive.google.com/file/d/0B2Z8JsO7iPb_ZEltbE5FUG1kOG8/edit?usp=sharing
I tried on bout machines:
All firmwares from g20.42 to g20.C8
Tried SSD fix firmware ( i know it's not related but what the heck :) )
Tried to format drive and start from g20.41 but didn't test machine yet
Thank you ALL for any kind of answer!
DadO
05-02-2014, 09:18 AM
Had a bad link for sharing. Now its fixed. (if only copiers would be this easy :p)
SmellsHot
05-02-2014, 12:04 PM
What program is this being printed from? Try to save as a PDF and try the print job.
Which driver are you using? PCL, PS?
minimerlin
05-02-2014, 07:22 PM
Looka like the sort of output you get with a duff MFP Board.
copier addict
05-02-2014, 08:09 PM
I have had a failing printhead cause problems like this. Check for printhead codes in service mode.
Hope this helps
Blizzoo
05-02-2014, 08:25 PM
Take a shot at Printer Control Board
Synaux
05-03-2014, 01:04 AM
Maybe PH board?
JR2ALTA
05-03-2014, 05:50 AM
run a stabilzation first before parts/boards
JR2ALTA
05-03-2014, 06:00 AM
DadO
05-03-2014, 10:03 AM
Here is another sample from another machine:
https://drive.google.com/file/d/0B2Z8JsO7iPb_RjZNbkY1YjhMT1U/edit?usp=sharing
One machine is using PS and another PCL, at least 90% of time.
I updated drivers whit newer version but didn't help in both cases.
Mainly Corel draw x5-x6 ver. and PS and ilustrator. Will ask costumers if they remember what program was from this 3 when problem appeared.
Will check for lasers codes and report back in monday
Thank u all for assistance ( and thx for this forum! )
AjitN
05-06-2014, 09:10 AM
I faced similar problem in C360, wherein there was flat cable at PH control board was defective.
Hope this helps.
tec
06-11-2014, 03:05 AM
Hi,
Any resolution to this problem? I have something similar on a +284.......
AjitN
06-11-2014, 04:32 AM
Hi
found any solution, just want to know
regards
Hansoon
06-11-2014, 06:56 AM
*removed*
Sorry.
Hans
EarthKmTech
06-11-2014, 11:33 AM
E4 firmware is the latest and has mentioned in the list of fixes colour registration drift. Sorry, cannot look at samples at present, but i know c8 firmware is old.
