View Full Version : Miscellaneous Help with a part number or description
optdoug
05-07-2014, 07:14 PM
Hi everyone,
I am looking for a part that is available for all Konica copiers. It's the little shelf that I have circled in the picture. I have tried to google it, but can't seem to find it anywhere. If Someone could supply me with a part number or part name that would be appreciated.
Thanks,
Doug
mo0651
05-07-2014, 10:45 PM
It's called a work tray. But most are different depends on the model of copier.
optdoug
05-08-2014, 01:54 AM
Thank you for the reply. The actual model I'm looking for this time is a Bizhub c351 but I will need others for different models. So I Googled Bizhub c351 work tray and I can't find anything. Is there another name other than work tray? It seems to be tough finding things for Konica copiers. I'm pretty new to the Konica copiers, so maybe I'm just looking in the wrong place. :confused:
Flash
05-08-2014, 01:57 AM
If this is a C550 it is a WT-502. Part# A07EWW0
optdoug
05-08-2014, 01:59 AM
Wow, that was quick! Thank you so much. I'll see if I can find it.
optdoug
05-08-2014, 03:22 AM
I did mange to find one. So thanks to everyone. But these things seem like an endangered species. There just aren't that many. I couldn't find any for older konicas like 7022's. I'll just have to keep my eyes open.
Hansoon
05-08-2014, 05:00 AM
Why don't you put your coffee cup just on the table?
Hans
mo0651
05-08-2014, 02:17 PM
You found one for a C351???? That has been discontinued for some time.
optdoug
05-08-2014, 04:36 PM
Hans
Hahaha, good one. But it's not actually for a coffee cup. It's to mount a cbord card reader.
optdoug
05-08-2014, 04:42 PM
I didn't actually find one for a C351. The one I found is for a 601. I have seen a few different models that have them, and they all look like the screw holes are the same distance apart. Maybe the one I found online won't fit on a 351, but I can probably drill holes in the shelf if it does not fit.
Mr Spock
05-09-2014, 12:42 AM
some of those work on many models. One has a mounting bracket for some models where it was not included in the factory.
